Hello, can someone tell me which capacitors I can use?
Thanks.
Hello Parls,
To help find the best match, you will need the dimensions of the square plastic base, assuming these are Surface Mount Capacitors.
Click here for a datasheet that will help decipher the top markings
The top one should be a 330uf, 6.3V capacitor. Click here for possible matches.
The bottom one should be a 470uf, 25V capacitor. Click here for possible matches.
Please check the datasheets, and measure your bases, and find an appropriate sized capacitor.
If there are no matches, we can go up in voltage to see what we have.
Hello, thank you for your helpful answer. have a good day!
