Articles and Resources for 3D Printing Projects
Digi-Key has articles located across our site to assist you in all stages of your 3D Printing needs. Here is a compiled list of topics that I found interesting:
Introduction to 3D Printing:
Design Resources:
Trouble shooting
Projects:
Products:
3D Printers and Related Products are located in Digi-Key’s Prototyping, Fabrication Products category.
i work at an auto repair facility. is it common to use 3d printing for car repair parts?
I wouldn’t say that it is common but you definican use a 3DP for that. What you will probably want is a stronger material like Nylon ¶ if it is going to be a functioning part.
What kinds of parts were you looking to make?
Bigger parts like a (plastic) bumper for example you would have to dove-tail smaller piecestogether over multiple prints. So it would take some time. Then I imagine you would want to weld them or glue them together bondo and sand/paint to get a finished part. It is all easily doable apart from the design work on Fusion 360 or the like that would be challenging once but then when you have the model you could just reprint and reprint after that.
Lmk if you have any more questions.
It could be a useful tool for you if you had the right printer.
Here is another one that 3D printing enthusiasts Common Problems When Making 3D Printing-2 - 3D Printing - Justway
The article outlines common problems 3D‑printer users face and how to solve them. It discusses over‑extrusion — when too much filament makes blobs — and recommends reducing flow rate or verifying filament diameter. It warns of prints not sticking to the bed, suggesting checking the bed level, cleaning the bed, adjusting the initial layer height, or using adhesives. It covers nozzle blockage and advises regular cleaning and clearing clogs. It notes inconsistent extrusion, fixable by tuning extruder tension and calibration. Finally, it describes Z‑axis wobble causing layer distortion and recommends tightening lead screws or adding anti‑wobble hardware.
