Auralic 25 8A 27
Hi, I can’t identify component 25 8A A27, probably a voltage regulator. It is part of the processor motherboard of an Auralic Aries g2.1. Thank you
Hello cp1,
I don’t see any unique markings that might allude to the manufacturer of this part. I attempted to find a schematic for the Auralic Aries but was unsuccessful in finding anything useful. If you can get your hands on the schematic, it may help us identify the part. Apart from that, I’m not sure what we’d need in order to identify it.
Regards,
Klint
Thank you so much! I’ll try! Thank you very much.
You are Welcome!
He started working again. There remains one last element on the USB that we can’t find. Can you help me? I attach photos
It is - TPS2065CDBVR
Thanks . I left this component burned in the auralic Aries g2.1 . Which in theory only interests the USB. Because replacing the previous one the processor is restarted but the Aries still gives me an error that does not hear the digital output. I don’t think I can depend on this component on the USB that we will fix anyway. Because if not we have no idea why you don’t hear the digital outputs (despite being on since the optical output is illuminated)
Everything works with Wi-Fi network except digital outputs. I’m also attaching photos out of curiosity. Thanks a lot
Hi cp1,
After looking at that last pic I did not see anything visually wrong with the board. I’m not sure what you’re referring to here. Please elaborate.
