I am developing a prototype which requires that we can program the blank oscillator by ourselves using the time machine II.
I want to order the blank oscillators from you so we can program the frequencies we need.
Since it is still in prototype stage. There are two oscillators I want to use and compare.
SiT8209AI and SiT9121A1 (LVDS)
7x5mm is preferred but can be 5x3.2mm
10ppm is preferred but can be 20ppm
We can program the rest if I understand the part number correctly.
We could order a large quantities when the prototype is approved.
Do you have those blank parts available ?
