I’m looking at getting some cables to suit a special PCIe crard I have, however I’m not sure if these ones will fit due to the space constraints of each header on said PCIe card. The latches on either side of the plug make it slightly too wide. Is there a version without the latches by any chance? See attatched image.
I know for sure that they will be too wide, that’s why I’m asking if there is a version of cable assembly on DigiKey with a plug similar to this one instead:
I wasn’t able to find a cable assembly in our system with a 2mm pitch, 10 position connector with dimensions you need. You can send your request to custom.orders@digikey.com to see if they can assist with your cable assembly. They would need the DigiKey part numbers of the connector and cable you will be using. A drawing of the cable assembly you want made and the quantity.
