Connector Identification
Looking for a part number for this connector.
Welcome to the TechForum. Is there any way you can measure the pitch.? This would be measured from the center of one hole to the center of the next one? I tried to calculate with the full length and was not getting what I needed. Here is the link I found so far: 6 Rectangular Connector Housings | Rectangular Connectors | Electronic Components Distributor DigiKey
Once you measure that , you can narrow down the search by clicking ont he pitch and applying filters. You can see if one will match.
Appears to be 2 mm pitch. Thanks for your help but none of the connectors DigiKey carries appears to be a match.
I cannot see the locking mechanism very well, but something like this might work. 0151360606 Molex | Cable Assemblies | DigiKey
