Can you tell me how I can attach this ribbon? Connector was broken
Can someone tell me if I can somehow connect this ribbon into the connector? the part waas cracked…
It didnt work when I just taped over the ducting tape.
Add images
Hello @denoo,
Welcome to the TechForum Community. The FFC connector on the PCB should be replaced. If your able to figure out the pitch of the connector, please see if one of the FFC connectors here might work. Please double check the dimensions from the datasheets.
Thanks!
