I am unable to identify the manufacturer of this part by the logo or the part numbers, though I suspect its a 4606 Mosfet. Any help would be greatly appreciated. Its from a battery powered rechargeable fan.
Hello cboatin and welcome to the forum,
I couldn’t ID that one myself, but if what you say rings true then BSO110N03MSGXUMA1CT-ND might be a good candidate. Can you take a picture just a touch more zoomed out so we can see the Net under the chip? If the traces only have 3 connections, then I think you are right.
Give special scrutiny to those three top left pins there. Based on what I can see I do not have confidence that it will work as a substitute, as I don’t know if S1,2,3 being tied together matches the intent of the PCB operation you have pictured.
A boost to my confidence would be if those three pins shared the copper trace.
I don’t recognize that logo, but I suspect it’s a dual MOSFET with an N and P-channel inside.
The AO4606 looks like the same internal layout. I don’t know if the electrical specs match, and we have no stock, but it’s likely a similar part.
Assuming the theory above is right, the AO4629 or the AO4616 might be worth considering.
