Hello I just try to start with Scheme it and It is just impossible to drag and drop any component. How can we allo the drag and drop.
I have started a new project but still the same. I tried with Chrom and explorer still the same actually I can not do anything with this software.
thanks
Hi Pidofra welcome to TechForum. You might what to clear your cookies and cache to see if that works, and verify that you are registered and logged into Digi-Key. If it still does not work, you might restart your computer to see if that might just be a glitch in logging in. Please see the link below for a help document below that might be of help. Glenda
Hello
Look I tried everything you said.
I cleaned all the cookies and so on,
I watched all the videos on utube already regarding digikey and scheme it.
But still the same, after loggini, When I grab a resistor for example drag and release it simply disappear, doesn’t stay on the sheet same with other component.
So
One other way to select symbols/components is to double click on them, maybe try that?
(? @Cody_Walseth )
I did but it doesn’t work either
If I click and drag then I can see the chosen component moving over my sheet but as soon as I release the left click it disappears
Thanks.
Hi @pidofra a couple things you can try:
- Clear browser cache
- Make sure you have JavaScript enabled
- Try using your browser’s incogneto/inPrivate window - some browser extensions may cause issues and this will rule those out.
I have the same drag and drop problem now with Scheme-it, I have been using this tool for years and never experienced that issue before. I cleared the cache and verified that javascript was enable, no change I also tried incognito window without any positive results.
please help me as I need to design new schematic.
@jeepye - can you confirm the same issue in an incognito browser window? If that doesn’t help, can you explain a bit more detail about what is happening - are the components now showing up or dropping, is it only schematic symbols, diagram symbols, the new Ultra Librarian symbols, etc…
