Thank you very much I will most certainly check this out .again thank you
Hello jessegrob94,
As I recall you purchased radial-cap type capacitors. They are considerably smaller than the original paper capacitors in your picture.
One trick that I have used in the past involves terminal strips such as this Keystone part. Since the new capacitors are so much smaller, it is possible to mount them underneath the chassis. My solution looks something this this sketch:
Happy soldering,
Aaron
Removed for user protection
