Configuration PROMs for FPGAs
This Product Selection Guide contains information to help select products in the Configuration PROMs for FPGAs category on DigiKey.com
Configuration PROMs (Programmable Read-Only Memory) are companion devices to FPGAs, used to store a user’s desired configuration for the latter during periods when the device is powered down. The specific memory technology used varies and includes types which can be electrically erased and re-written, rendering their characterization as “read-only” devices somewhat anachronistic.
SelectionCharacteristics
DigiKey Programmable: For verified products, DigiKey can program/flash your compiled code or configuration variables prior to shipping. For unverified products, please inquire with ProgCent.Techs@digikey.com.
Programmable Type: The method or technology used to store the configuration data that defines the logic and functionality of the FPGA
Memory Size: Indicates the amount of memory available on the device.
Voltage - Supply: Typically represented by a range, this indicates the low and high voltage limits which one can expect standard operation. Voltages outside this range may damage the device and other system components.
Mounting Type : Indicate how the device is attached.
Supplier Device Package:
ProductExamples
MFR PART # AT17LV256-10NU
DIGI-KEY PART # AT17LV256-10NU-ND
MANUFACTURER Microchip Technology
DESCRIPTION IC EEPROM FPGA 256KB 8-SOIC
DATASHEET Click Here
MFR PART # EPCQ16ASI8N
DIGI-KEY PART # 544-3440-ND
MANUFACTURER Intel
DESCRIPTION IC CONFIG DEVICE 16MBIT 8SOIC
MFR PART # AT17F040-30CU
DIGI-KEY PART # AT17F040-30CU-ND
DESCRIPTION IC FLASH CONFIG 4M 8LAP
If you have any general questions on the specifications for selecting Configuration PROMs for FPGAs, please reply using the button below. If you have questions on specific Configuration PROMs for FPGAs please post those questions in the Integrated Circuits (ICs) category.
