I currently have a 6 pin camera. is there any connector to connect to the DS90UB960-Q1EVM FPD Link III port ?
achertov
Thank you for contacting DigiKey , what is the part number for the camera that this connector is on ? are there any markings or numbers on this connector that may help us identify it ? the only info I am seeing is that the DS90UB960-Q1EVM uses a Quad Mini-Fakra to 4x Single Fakra coax cable assembly (not shown) for interfacing the EVM to up to four sensor modules . per the data sheet , Page 5 https://www.ti.com/lit/ug/snlu226b/snlu226b.pdf
Thanks Craig
36560TJBAI20MI
This is a rivian backup camera
Hello achertov,
I checked our system and I wasn’t able to identify a mating connector to the one you have.
Thanks,
what about a circuit board ?
Hello achertov,
What kind of circuit board are you looking for?
if there is no connector is there possibly a board that accepts this 6 pin connection which could then be mounted on the DS90UB960-Q1EVM
