Connector identification
I have a replacement part that came with a flat ribbon cable, but no end connector to connect to the circuit board. Can someone advise me of the component I would need to purchase ? The old connector has a black termination in the pictures…
Hello @mellis8888
Possible option for this type of flat flex cable connection we have AMPMODU Mod IV series.
IDC Termination Contact A25944-ND
Housing part numbers
3-87499-2-ND and A111776-ND
Unfortunately the housings were not in stock having minimum order requirement.
Is there a non crimp connector that would simply clamp onto the new flat conductor cable ? Possibly like the picture that I could use a jumper cord to the circuit board pins ?
(attachments)
The type of flat cable shown in your photo use contacts that press down and pierce into the cable such as 102348-3.
Which is a different type of cable from those that have exposed conductors that press into those low insertion force / zero insertion for FFC connectors.
Do you have a connector (not with a circuit board attached) That would pierce the type cable I have AND plug into my circuit board ? That would be fine, as I do not have a crimping tool to make the connection you sent before.
