Connector type?
I am looking for a replacement connector however the only thing I found that is close is a SM connector. I’ll attach photos/datasheets. It is suppose to have a clip a end.
The pitch is 2.54 and I could tell that there was a HRS stamped on the housing.
Hello TechMonkey!
That SM connector looks like it would be a solid direct alternate assuming the pitch and row spacing are correct, are you able to tell if there are any codes marked on either of the plastic housings?
So far I have found these options: https://www.digikey.com/en/products/filter/rectangular-connector-housings/319?s=N4IgjCBcoBw1oDGUBmBDANgZwKYBoQB7KAbXAFYwBOAJipAF0CAHAFyhAGVWAnASwB2AcxABfAjHrQQySOmz4ipEFQDsNAGyMW7SF16CR4kDTDqEM1JlwFikMjW0g2HAJIDWOITh5jRooA
However, Hirose isn’t one of them, and that’s what your “HRS” calls out
Other than the HRS there are no visible codes on the connector.
Hi @TechMonkey ,
H3761-ND | H3718-ND look like what you need, however unfortunately there is no stock and I wasn’t able to locate any in-stock crosses at this time.
That appears to be the connector that I’m looking for. Thanks for the help and if I can get one I’ll see if I remember to update this.
