Contact pin include or not include for TE Connectivity part
------Question for CSA264N00450001000 & CEDE271NN00000051000 Please Put your question below------
Please advise if I order this part its already get contact pin 4 x dia 3.6 and 4x dia 2.0 mm ?
If not include how to order ?
We plan to order 1 pc for each model
If we order more than USD 150.00 its will get free shipping cost to our address in Limus Pratama Regency, Jalan Tegal 2 Blok G6 No.16 Cileungsi-Limus Nunggal 16820, Kabupaten Bogor, Jawa Barat - Indonesia
Hello @jayasaktianugerah67,
Please note that the TE Intercontec Series 940 plug (CSA264N00450001000) is sold as an empty housing and does not include any contacts as per DS:
CSA264N00450001000
You will need to purchase the power and signal contacts separately to complete the assembly.
This connector requires 4 power pins (3.6 mm diameter) and 4 signal pins (2.0 mm diameter).
Below are the matching DigiKey part numbers contacts links for CSA264N00450001000 according to TE.
For the ø2mm contacts:
60-0254-011-P00 TE Intercontec | Circular Connector Contacts | DigiKey
60-0302-011-P00 TE Intercontec | Circular Connector Contacts | DigiKey
For the ø3.6mm contacts:
60.225.11 TE Intercontec | Circular Connector Contacts | DigiKey
60.227.11 TE Intercontec | Circular Connector Contacts | DigiKey
Same for the CGE271N00000051000 it’s sold as an empty housing and does not include any contacts as per DS:
CGE271N00000051000
