For Conta-clip 10-position terminal block cross jumper, 2080-2425.0-ND, for use with 2080-17112.2-ND,
can I safely cut the 10-position jumper assembly into pieces to get shorter cross jumpers? What I really need is 3 2-position cross jumpers, but the 2-position parts are not in stock. Thanks!
Well, that would probably depend on one’s physical dexterity and skill with the tool chosen for the task…
Kidding aside, I see little reason why that couldn’t be an answer to the problem at hand.
