If a bridge/jumper is being used to connect multiple CLIPLINE MT terminal blocks together, the tab located in the center of the housing needs to be removed. A needle-nose pliers, like 277-2472-ND, can be used to snap the tab off.
Screw Terminal Bridge/Jumper
