Depth of RJ45 right angle connector
DigiKey Product N204-005-BL-RA
I need to confirm the depth of this RJ45 connector. Specifically the depth from where the connector sits hard up against the ethernet port to where the right angle occurs. These dimensions don’t appear to be detailed on the available datasheet. The installation has limited space, hence I need to confirm prior to purchase.
Thank you in advance!
I am checking this measurement. I will let you know when I have the answer.
We measured N204-005-BL-RA. It measures 17.6 ~ 17.9 mm.
Brilliant, thank you for checking this.
