DigiKey Coffee Cup Counter Demo via 2x20pin GPIO Header on FPGA Cyclone 10 LP Evaluation Kit
The present demo will implement a basic counter in the Intel® Cyclone® 10 LP FPGA evaluation kit via the 2x20 GPIO header.
The low cost Intel® Cyclone® 10 LP Evaluation Kit provides a very easy-to-use platform for checking out the performance and characteristics of the Intel Cyclone 10 LP FPGA device. In a previous article, it was described how to implement a virtual JTAG interface in this Cyclone 10 LP FPGA board.
In this demo the following GPIO header will be used to output the signals from the counter.
The specific verilog HDL used in this demo is this one,
// Digikey Coffee Cup Counter for 2x20 GPIO header for Intel Cyclone 10 board
module counter (
    input wire clk, // 50MHz input clock
    output wire GPIO0, //GPIO0
    output wire GPIO1, //GPIO1
    output wire GPIO2, //GPIO2
    output wire GPIO3, //GPIO3
    output wire GPIO4, //GPIO4
    output wire GPIO5, //GPIO5
    output wire GPIO6, //GPIO6
    output wire GPIO7, //GPIO7
    output wire GPIO8, //GPIO8
    output wire GPIO9 //GPIO9
   reg [31:0] counter;
   initial begin
      counter = 0;
   end
   always @(posedge clk)
   begin
      counter <= counter + 1;
   end
   assign GPIO9 = counter[31];
   assign GPIO8 = counter[30];
   assign GPIO7 = counter[29];
   assign GPIO6 = counter[28];
   assign GPIO5 = counter[27];
   assign GPIO4 = counter[26];
   assign GPIO3 = counter[25];
   assign GPIO2 = counter[24];
   assign GPIO1 = counter[23];
   assign GPIO0 = counter[22];
endmodule
Everyone knows, which is not the goal in this endeavor here, that there are GUI tools and paradigms out there that facilitate this assignment process, but is a good exercise to go thru your system, that is why we are going thru this manual process. The relevant diagram of this 2x20 GPIO port in the Intel® Cyclone® 10 LP FPGA evaluation kit is shown below,
The required I/O definitions to complete this demo are shown below,
    set_location_assignment PIN_L13 -to GPIO0
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO0
    set_location_assignment PIN_L16 -to GPIO1
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO1
    set_location_assignment PIN_L15 -to GPIO2
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO2
    set_location_assignment PIN_K16 -to GPIO3
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO3
    set_location_assignment PIN_P16 -to GPIO4
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO4
    set_location_assignment PIN_R16 -to GPIO5
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO5
    set_location_assignment PIN_N16 -to GPIO6
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO6
    set_location_assignment PIN_N15 -to GPIO7
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO7
    set_location_assignment PIN_N14 -to GPIO8
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO8
    set_location_assignment PIN_P15 -to GPIO9
    set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to GPIO9
The Sparkfun Logic Analyzer was connected to verify the signals in the 2x20 GPIO header port as shown in the next picture,
The following Sparkfun Logic Analyzer capture confirms the proper operation of the demo as shown below,
The Intel® Cyclone® 10 LP FPGA evaluation kit is an excellent powerful platform for developing many applications and is available at DigiKey.
Have a great day!
This article is available in spanish here.
Este artículo está disponible en español aquí.
