Diodes in opto-isolator
Can anyone please identify the part number for the diodes used in this opto-isolator breakout? The datasheet does not list any part numbers.
Note: not the diodes inside of the actual optoisolator chip, but the two surface mount diodes.
Link: SparkFun Opto-isolator Breakout - BOB-09118 - SparkFun Electronics
Thank you in advance!
Greetings,
The schematic here for the board indicates that those are transistors rather than diodes, and doesn’t specify a particular part number either. Given the intended use and configuration, most any small-signal NPN would suffice, with the '847 & '3904 being some of the more ubiquitous generics of the type.
