Hello…how can I place a dotted line (or dash line) box around a portion of the circuit? For example, I would like to place a box around the power supply section in a radio schematic, without affecting the components or layout.
Thanks very much.
Thanks very much.
Hello @emilzelasko,
I was able to replicate a dotted outline but it was sort of a round-about way to do it:
If this will work for you, here are the steps on how I did it:
I’ll keep researching this to see if there is an easier and quicker way to do this.
~Lindsay
The other option you have is you can click and drag your mouse over a section of your schematic. You should then get a pop-up on the right of the screen and you can select group. This will place a box over those components.
Here you can see I grouped some random components.
Perfect…thanks very much!
