Hello, has anyone found a way to get an onscreen keyboard for the EDATECH Pi Based HMI’s?
4555-ED-HMI2020-101C-1408-ND as an example
Welcome to the community cmaxwell!
You’re looking for an onscreen keyboard that will work with a Pi based HMI. I took a look at the data sheet and confirmed that they are running the raspberry pi OS. All you should need is to download and install one. I found a tutorial at this link.
I do hope this helps!
Hello @cmaxwell and @AaronRollens,
This is EDATEC Technical Support.
I would like to confirm that the behavior of the onscreen keyboard has indeed changed significantly with the latest updates.
The Key Timeline (November 2024 Update): If you are using the Raspberry Pi OS image released on November 19th, 2024 (or later), the system default compositor was switched from Wayfire to labwc.
Pre-November 2024 (Wayfire): The virtual keyboard was not fully integrated. Users typically had to manually install matchbox or wvkbd and set up toggle scripts (as Aaron correctly suggested).
Post-November 2024 (labwc): The OS now comes with Squeekboard pre-installed and integrated. It supports automatic popup on touch events and is natively managed by the system.
Recommendation:
For New Images: If you are running the latest image (check with cat /etc/rpi-issue, looking for dates after Nov 2024), you should see the virtual keyboard work automatically with touch inputs.
For Older Images: Aaron’s guide remains the correct solution.
Best regards, EDATEC Technical Support Team
