This Product Selection Guide contains information to help select products in the Environmental Testers category on DigiKey.com
Environmental testers and equipment include any tools designed to measure environmental conditions. This includes conditions such as: acceleration, pressure, temperature, light, air flow, humidity, carbon monoxide, formaldehyde, electromagnetic fields, fluoride, water quality, and much more. The types of tools found here include: anemometer, infrared camera (IR, thermal imaging), dosimeter, photometer, sound level meter, psychrometer, and moisture meter, among others.
SelectionCharacteristics
Type: The type, style, or nature of the device.
For Measuring: Indicates the quantity, process parameter, or other variable(s) that a device is intended to measure.
Includes: A description of what the item comes with.
ProductExamples
| MFR PART # | FLIR C5 |
| DIGI-KEY PART # | 2067-FLIRC5-ND |
| MANUFACTURER | Teledyne FLIR Commercial Systems |
| DESCRIPTION | Infrared Camera, Thermal Imager For Measuring Temperature (Non-Contact) Includes Battery |
| MFR PART # | MR176 |
| DIGI-KEY PART # | MR176-ND |
| DESCRIPTION | Infrared Camera, Thermal Imager For Measuring Humidity, Temperature Includes Battery, Cable, Case, Charger, Lens Cap, Manual, Power Supply, SD Card, Strap |
| MFR PART # | ET110 |
| DIGI-KEY PART # | 1742-1250-ND |
| MANUFACTURER | Klein Tools, Inc. |
| DESCRIPTION | Gas Analyzer For Measuring Carbon Monoxide Includes Battery, Case |
MediaLinks
Videos
Klein Tools’ Rechargeable Thermal Imager
Thermal Imager confirms that lava is super hot
Seek Reveal Product Tour
REED Instruments Moisture Meters
Klein Tools Test and Measurement
REED Instruments Compact Series 19xx
Klein Tools Digital Light Meter
Klein Tools Carbon Monoxide Meter
Fluke ii900 Sonic Industrial Imager
See everything at once with MultiSharp™ focus
Refrigerant Gas Leak Detector
