Trying to identify the crimp terminal socket that are used with this connector.
The socket is typically found on Ford inertia switches.
Measures 19.5mm long, 4.00mm wide, and 3.00mm tall.
Has a cutout at the top of the terminal that allows a plastic clip that is molded into the housing to latch into place.
I’ve been combing through all of TE’s connectors and have yet to find one that matches perfectly.
Any help would be appreciated.
Hello @cb7axemonkey
Welcome to the TechForum
Unfortunately, I was not able to find this contact terminal on our site.
I did find that Ford also calls this connector a fuel pump cut-off switch connector, but it did not lead me to find what contacts or housing is used to build this connector since most are sold as complete connectors with pigtail ends.
There may be someone else that might be able to find it, but I was not able to find a replacement contact.
Thank you for taking the time to try and find it.
I know I’ve spent way too long to try and locate this particular crimp terminal, may just have to go a different route.
