FFC Cable
I need an FFC cable, almost identical to a DigiKey
WM25145-ND. The difference is this one has both ends for socket insertion. I need a similar cable (length, pitch, etc.) with one end for a socket and the other end to be soldered onto a board. Can I get help sourcing this?
Thanks,
Trish
Katrisha,
I was unable to find a FFC like this that will solder to a circuit board on one end.
One option would be to solder a connector on the board, Click here for some options.
Then you can use the WM25145-ND and plug it into the connector you soldered to the board.
