I need to find the best time-delay relay for a specific application… I would like to be able to manually turn a wall switch on, then power flows to the time-delay relay, before it reaches the light. The time-delay relay will allow power to flow to the light for 10 minutes, after which the light turns off, even though the wall switch is still in the on position (ie. there is still power flowing to the time-delay relay). The time-delay relay would automatically reset as soon as the wall switch is manually turned to the off position. The next time the wall switch is turned to the on position, the cycle would restart again. Can anyone recommend the best time-delay relay for this application? Thanks.
Thanks Rick, appreciate the help, we’ll check it out.
