Hi,
I’m trying to replace a vertical PCB incremental rotary encoder with push switch from a VWR/LabXter incubator control board. I am wondering if you can help identify it. If this is a custom type thing or stock.
Details:
3 encoder pins on bottom side
2 switch pins on top side
6 large mechanical support tabs
vertical mount
continuous rotation, with vibrate feel but not locking into slots
split serated
Switch_Identify.pdf (724.9 KB)
shaft
shaft diameter 5.9 mm
shaft height from PCB about 19 mm
body about 14.3 x 12.1 mm
The metal can is stamped, see images, but might be a mfg number.
I appreciate any help you can provide.
Thank you!!
Jon
