Help identifying part numbers - diodes
I’m fixing a headlight retractor control module on my 1985 Toyota MR2. It’s the PCB that controls the pop-up lights. I’ve identified some shorted diodes I want to replace, but I can’t seem to see a part number and I don’t know diodes very well.
The space between holes on the board is 10mm. The diode is a small black cylinder with a diameter of 3mm and a length of 5mm. I can’t see a part number on the diode except for E 5E. The marking on the diode is pink.
When I put my DVOM in diode mode on a good diode it reads 0.536V forward voltage. and OL in the other direction.
Can someone help me find a replacement part number?
I’m attaching a photo for reference.
Unfortunately, I could not identify this one.
No problem. It’s hard when there’s nothing written on it.
Do you have a part number for a high quality 1N4007 through-hole diode?
I’ve done some reading and that should work.
The manufacturer of the diode should not matter. So any of the options on the link should work fine.
Take a look at this link for the 1N4007 part numbers.
https://www.digikey.com/en/products/filter/single-diodes/280?s=N4IgjCBcoGwJxVAYygMwIYBsDOBTANCAPZQDaIALGGABxwDsIAuoQA4AuUIAyuwE4BLAHYBzEAF9CYAExwI0ECkgYcBYmRABmCgAYw9CIW06d9CiEI1Tm%2BtItb9YODvuadMM3ZYgOXXoNEJQgBaOwUlfgBXNRJIcgBWZkkQYIRwqCiYjQgmcWSw8jAAOV1TJKA
Thank you! I got some and replaced the diodes but the board still has a fried part. I’ll do another post about this.
