Hi there, I am struggling to identify/connect the pins of your pressure sensor: ELVH-001G-HAND-C-NAA5. The data sheet doesn’t explicitly label each pin, please help!
Hello Paz,
Welcome to the DigiKey tech forum community.
The pinout is actually given on the data sheet page 10 where the ordering code is seen.
In the NAA5 suffix of this part number is where the pinout reference is mentioned. The A immediately after the N designates the pin code and then the pin code table on the same page identifies each pin.
Hope that helps.
Thank you SO much! That is incredibly helpful!!
