Help in identifying power plug
Hello, would you please help identify the power connection in the photo? The pin housings measure 2.4mm wide 6.6mm in length, and the overall height with the retainer is 8.7mm.
Thank you!
Hi Nick, Could you provide the pitch of this connector which is the center to center measurement between the pins? You can also obtain this measurement by measuring the leading edge of one pin housing to the leading edge of the adjacent pin housing.
Looks a lot like a 794617-2 or clone with a custom overmold. Latch looks different but possibly compatible, and the shroud keying looks like it may be compatible also.
