Help me to get similar product of other make
I want you to suggest me equivalent product of McMaster make, Product Code - 5106N24. Description of product mentioned below:
Continuous Flexible cable, 300V AC, Two 18 SWG Wires, unshielded, stranded wire type, OD 0.24", Bend Radius 1.8", Outer insulation PVC, colour - Gray, Inner insulation - TPE Rubber, Color - Black, Clean
Welcome to the DigiKey TechForum. Closest options I could find based on your description are these cables . Take a look to see if one will work for you.
