Help needed to identify two capacitors
I’m needing a little help to order the correct capacitors. I don’t understand the nomenclature to order the parts.
One cap says ITT 6.3v 220uf and the other KE 47 uf 16v (E3) + FPF
Given current inventories and, assuming only one of each is needed, I’d order these:
227TTA016M Cornell Dubilier Knowles | Capacitors | DigiKey
MAL202136479E3 Vishay Beyschlag/Draloric/BC Components | Capacitors | DigiKey
Thank you so much Paul. I just don’t understand the catalog. I ordered them today.
Monte
