I helping finding correct on/off switch
I need help finding a on/off switch for a presonus eris 4.5
I’ve searched the internet for exact dimensions but when i place an order through DigiKey, it didn’t fit.
Pictures are of the original switch. Damaged it prying it off the glue it was stuck to and unable to read part number.
Greetings,
That’d most likely be a double-pole, single throw rocker switch.
Options for a round cutout aren’t all that numerous, but if any of the options under the Panel Cutout Dimensions match the existing hole size, they’d be worth consideration.
Hello @Jpatx
Welcome to the TechForum
I narrowed down our list of circular rocker switch, and the best option I could find is 471017268142 which has a 20mm panel cut out size. I know you mentioned a problem with getting the switch you ordered before to fit into the hole on that speaker, would you be able to measure the hole size on that speaker?
