I’m currently looking for a 2×13 (26-pin, 2.54 mm pitch) socket header — ideally with extended (long) pins.
If a long-pin version is not available, a standard pin length could also work as an alternative.
Thank you!
Thank you!
Hello david4,
The closest match I found is part number SSW-113-03-G-D-ND, which has long pins that are 10.01mm length. Please check the datasheet, to verify compatibility.
