I need pins for the 206852-8 connector body that I have
I have client that handed me a connector body as noted above. It has no pins in it, but needs some. The spec sheet/drawing for the connector has NO reference to the pins that go in it. I have searched you web site for some connecting info but have found none. Can you help me get these correct pins sop I can order them?
Thanks.
See this document for references to contact part numbers for the connector series–housing is on page 26, contacts on page 29. What you’ve got there would appear to be a receptacle for pin contacts, and there are a few different options available, based on wire gauge, finish, etc. Some options that are currently stock can be found here.
Rick,
Thanks for the info. It was just what I needed.
JG
