I require 1 Diode bridge or equivalent. RVB-608. 1 power transistor MP1620 power transistor MN2488
For your Bridge Diode, kindly see if the following will work for you.
dianne42
Thank you for contacting Digikey , for the RVB-608 I am not finding that number is it RBV-608? if so take a look at our part number 4878-GBI40K-ND check data sheets to see if this will work for you . For the MP1620 we do not have this part or a replacement to offer for it . For the MN2488 we do not have this part or a replacement for it .
Thanks Craig
