Identification of component
Hi!
Need help identifying these components.
And also if there is a similar i can buy on DigiKey.
Thanks in advance
Kind Regards
Mikael
Hi flockisson
This appears to be an RC network. We do not offer the exact value. Click here for a link for the closest options DigiKey offers.
Hi flockisson,
We do normally stock one other RC snubber which has somewhat closer electrical specifications to your part, but it is currently on back-order. It is the P409EL474M275AH680, rated for 68Ω, 0.47uF, and 275Vac/630Vdc. I can not tell whether the physical form-factor could work for you, but it has the dimensions highlighted in the diagram below from the datasheet:
The parts are on order but I don’t know when they might be coming into stock. If interested, you can send an inquiry to sales@digikey.com.
Thank you so much for the info, will contact you if I need to order. What is the expected lead time?
Send an inquiry to sales@digikey.com for questions about lead time.
