Identify and locate blade connector
need to identify and locate this 10 blade surface mnt connector. Any help appreciated. Kevin
Welcome to the TechForum.
I was able to locate 3 close options and just need the pitch confirmed in the filters.
Blade Type Power Connector Assemblies | Blade Type Power Connectors | Electronic Components Distributor DigiKey
Thank you
Ryan
MICS 10 looks like it. It’s 0.5in spacing. I need surface mount. That is through hole.
Do you know if there is a surface mount available?
Hello @locomotive751
Unfortunately we did not have a surface mount version of part number 5405-MICS10-ND. I was unable to locate a match to your supplied photos.
Thanks for checking
Hi locomotive751,
It looks like Lumberg part number “MICS/SMD 10”. We don’t carry it, but it does show up in a Google search.
Thank you, I’ll check with Lumberg and see if it’s still available
Kevin
