I would like to know if these Amp components work correctly together and if the tooling I have selected is correct for removing both male and female pins as well as crimping both? If something needs to change or be added could you let me know what that would be? Please see my list at https://www.digikey.com/en/mylists/list/4NY10ZMHLN
ldjesse,
It looks like all these should work together. Both contacts are gold plated with the same wire awg size.
They are associated to the correct connectors. The connectors have the same X keying and one is a 6pos plug, and the other is the 6pos Receptacle. The Crimper will crimp both the Male and Female contacts, and the extractor is for the D-1000 series. You should be good to go with these. I would order a couple extra contacts, just in case.
Thank you very much for this information.
