I need help to identify a power connector used in a replacement power amplifier board on my ADAM A3X studio monitor.
I cannot get information from ADAM Audio in Germany, and none of their distributors have been helpful.
I have attached two photographs of the mystery connector. Markings are on an inch scale.
power_connector_1.pdf (1.4 MB)
power_connector_3.pdf (1.2 MB)
Please review my attached photographs to identify this connector (I want to purchase two sets of these connector types).
Thank you very much for your willingness to help.
@wrstrand
Would you be able to directly measure the center to center contact distance that has.
The rectangular jack receptacles are approximately 3mm by 1.8mm in size. Center to center separation is 7mm. The jack receptacles are 4mm apart on their medial surfaces, and 10mm apart on their outer surfaces.
Thank you.
William Strand
transverse.pdf (530 KB)
vertical.pdf (386 KB)
@wrstrand
I am sorry to say that I have not had luck locating the item you show in these images.
Hi wrstrand,
I found your connector. It’s the JST VL series, part number VLR-02V.
It mates to the VLP-02V.
Here’s a link to the associated contacts.
If you don’t want to have to crimp the contacts, we also sell pre-crimped jumper wires with various lengths and contact combinations.
