Importing the Digi-Key KiCad Library into KiCad 5.0.0+
There are several different ways to manage third party libraries like this one. Using git clone is a great way to keep it up to date.
How you decide to manage the library(s) within KiCad is open to debate, but the way I prefer to use them is to pull them in to the Project Libraries, that way they are managed separately from the default libraries, this can be done as such:
  1. git clone https://github.com/Digi-Key/digikey-kicad-library.git into your preferred directory
  2. Open KiCad
  3. Import the symbols:
    A. Open Symbol Editor or Schematic editor
    B. Click on Preferences then on Manage Symbol Libraries…
    C. Click on the Project Specific Libraries tab:
    D. Click on the Add existing library to table button:
    E. Navigate to the directory where you cloned the Digi-Key KiCad Library
    F. Navigate to the digikey-symbols folder within digikey-kicad-library folder
    G. At this point you can add one library at a time or all of the libraries. To add all of the libraries click on any one of the the libraries and then press Ctrl+a. This will select all of the libraries, then click the Open button.
    H. You should now see the libraries in the table:
  4. Import the footprints(similar process to symbols):
    A. Open Footprint editor or PCB Layout
    B. Click on Preferences then on Manage Footprint Libraries…
    F. Expand the digikey-kicad-library folder and select digikey-footprints.pretty
    G. Click OK
    H. The digikey-footprints should now show in your library table
Hi, migrating to KiCad and was looking for LED2472GBTR - is it missing or am I missing something? Thanks, Mike
