The hole size on the footrpint for the OSTTC022162 connector is incorrect. I had a board manufactured with this footprint, and the connector does not fit. I checked the OSTTC022162 datasheet, and it indicates that the hole size should be 1.3 mm, but the hole size on the footprint is only 0.76 mm.
I made a pull request to correct this issue, but I have not gotten any feedback on it: https://github.com/Digi-Key/digikey-kicad-library/pull/110 . What can I do to move this forward?
P.S. - I suspect other footprints in the OSTTC022162 family have a similar issue, but I have not checked.
