Insulation piercing crimp connectors
I am looking for Insulation-piercing FORK-STYLE crimp connectors for 18AWG wire. They have small stamped “teeth” that bite into the insulation of the wire, rather than having to strip the wire. I have included an image (I hope) of what I am looking for, the one in the image is too small, for 22-26AWG wire.
https://i.ebayimg.com/images/g/1p8AAOSwHOdmDvb4/s-l1600.jpg
Greetings,
While relatively uncommon, P/N 42339-2 does appear to be an item in stock that meets this description.
Thank you, Rick. DigiKey’s search system can be confusing, especially if you aren’t exactly sure what the item you’re looking for is called. Much appreciated.
