Replacing IRFP260M MOSFET. Is the information on line 2 “I?R P113J” and line 3 “60 EO” on the original part relevant? Will the STW75NF20 proposed by the Cross Reference tool for the IRFP260M work as replacement? Trying to fix a Treadmill. Cheers, Germain
Per the datasheet, Line 2 is the date code. Line 3 is the lot code.
You can use the RoHS replacement. IRFP260MPBF-ND there is stock available for this part.
