Is this a special order part #?
99s0636
is this a special order wire? i found this on a cable we have installed
I looked into those numbers and did not find a special cable or wire associated with that being a portion or whole part number. If you can send in an image, we could let you know what to look for and if you know the AWG we could offer some alternates.
Thank you
Ryan
I am just looking for the male pins already in the housing like this
Quite possibly something from the Mini-Fit Jr. series from Molex.
Not much to go on from the photo, but I’d suggest looking at the 2047230004 backshell (2x needed) and 0039014040 housing. Contacts for housing would be here, with selection varying depending on wire size and desired finish.
Again, that’s just a guess–check the datasheets to see how good a guess it is…
