I am looking for these connectors, Prewire if possible if not then with all of the appropriate pins etc.
thank you
-Perry
Hello Perry, Welcome to the TechForum.
The first picture listed looks to be from the Commercial Mate-N-Lok series from TE Connectivity.
The Plug part number is A1431-ND
The Mating connector, referred to as the Cap, is part number A1402-ND
The contacts are Sold separate. I am sorry, but we do not have any that are pre-wired already. This List of Contacts, will be the Pins and sockets that will work with those connectors.
The main thing to pick out is the AWG size for the contacts. If you need help let us know and we can assist with that and also any Tooling that you need.
The bottom two pictures look to possible mate together. Is that correct?
If so they do look like the Mini Fit Jr series from Molex.
The Plug looks to be a Panel mount style. Please look at 23-0015060040-ND
the Mating receptacle is a BMI style. Please look at 23-0015060045-ND
The Same goes for these connectors also. We do need to know what AWG size you are using to pick the correct contacts.
If you want to take a look the Pin contact options are Here
the socket contact options are here.
Also Tooling is available. If we get the correct contacts for you we can get you the correct tooling for it.
Please take a look at these and see if they will work for you.
If you have any questions let us know.
Thanks,
Paul
