Is TPS82130SILT allowed to be washed?
I might be missing the keyword but looking at the datasheet to see if TPS82130SILT can be washed after placement?
Hello juanc, thank you for the question! While there is no direct documentation of washability for TPS82130SILT, it was answered on TI’s E2E platform here:
TPS82130: Power Module Cleaning, any Guidelines/Concerns? - Power management forum - Power management - TI E2E support forums
This does make sense if you read the Micro-Sip documentation:
The utilized IC is embedded, so washing won’t cause an issue as long as it is dried or baked afterward.
