Hello, which battery do you recommend I buy for the Kittenbot Meowbit Card‐sized Retro Game Computer?
I am not certain what the original supplied specs would be for the battery.
Only data I found was 3.7-4.2v. but no data on size or expected connectors used.
The below like shows what I had found.
https://www.digikey.com/short/8v3r93t7
Here some specs 6x40x20mm 3.7V 450mAh Lithium Ion Battery with JST 2.0mm PH, 2‐Pin
connectorx1
here are options we have:
housing
455-1165-ND
contacts on wire
1528-2617-ND
