15mm long 4mm OD , it came out of a CO2 laser power supply. I cannot seem to find any close to it, with its size I would assume it is a high wattage or larger for heat dissipation
Welcome to the TechForum. Part 13-FMP300FRF73-180KCT-ND is in stock check the datasheet to verify for your application.
