Hi tomasovichm ,
This post will help direct you to the correct type of dimmer or potentiometer needed.
LED Driver Dimming Types
If you are using 0-10V/Analog/Low Voltage dimming, you may choose from these wall mount styles, or from our entire list of potentiometers to find what you need. Please review datasheet specifications to verify applicable to your application.
